Rendering showing weird behavior
Look at the images while rendering. Every time is giving me different colors and textures. I thought was the grass in the first image so I ‘ve deleted all the grass, but then is just a matter of showing different colors but not the image.
But when I’m in the view I can see all the building with shadows and every thing.
aRcHiTeCt.JM
…hi @Anonymous
… looks like your camera is rendering below level 0
…. the rendering engine is assuming that it will be rendering from below the level
... (like under the ground)
…. that is why you are getting that image
… you don’t need to delete anything
… just move your camera up at least ½ inch from the lowest level
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
@aRcHiTeCt.JM wrote:
…hi @Anonymous
You are right! My camera was under the ground. Thank you.
