Rendering Problems with Circles
10 ANTWORTEN 10
GELÖST
Nachricht 1 von 11
1004 Aufrufe, 10 Antworten
Hi so i am trying to render product of mine and when i do it the final image looks choppy as if it doesn't anti aliasing enabled but i do have that setting enabled. Any ideas on a solution ? ( See attached files for settings and the model it self and the rendered image)
Tags (2)
10 ANTWORTEN 10
Nachricht 2 von 11
als Antwort auf: Anonymous
*more pics*
Nachricht 3 von 11
Crank up Output Settings: Printer @ 300 or 600 dpi.
Nachricht 4 von 11
Try using a different Asset for your Material. You are currently using a Legacy Asset, as denoted by the orange, triangular icon.  Try one without.
Nachricht 5 von 11
als Antwort auf: ToanDN
Tried doing that but then i the overall quality of the image decreases, is  there a way to adjust the height and width?
Nachricht 6 von 11
Render Region instead of full screen.
Nachricht 7 von 11
RDAOU
@Anonymous
Change the scale of the view to 1/25 or 1/10 then render with Quality set to High and 150+ DPI
Nachricht 8 von 11
...it might look better when placed in a "scene".  If I were to isolate one element out of a pristine rendered scene, I think I would be disappointed by how that element looked all by itself.
Nachricht 9 von 11
als Antwort auf: barthbradley
Yeah thats probably the case. i'm probably just getting a bit to picky
Nachricht 10 von 11
RDAOU
It is definitely the case all experts say so...the scale vs resolution quality is an insignificant detail that skips their mind :leicht_lächelndes_Gesicht:
Anyhow, below is for those who might come across this post and wonder about the scenery when rendering a 5cm pipe fitting lol without scenery
Nachricht 11 von 11
als Antwort auf: RDAOU
I don't get it. What are you pointing out in your screenshot that is so funny?  I can't make it out.
