RENDERING NOT LOOKING REAL
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
367 Aufrufe, 5 Antworten
WHY THE RENDERING DOES NOT LOOK REAL? I SAW A COUPLE OF REVIT RENDERINGS VERY IMPRESSIVE, OR THEY THEY ARE MADE WITH 3DS MAX?
ALSO IM SHOWING A LOT OF CURTAIN WALLS IN THE FRONT ELEVATION BUT THEY RENDERED WITH FILLED SOLID MATERIAL? THEY ARE GLASSrenderingrenderingprojectproject
5 ANTWORTEN 5
Nachricht 2 von 6
aRcHiTeCt.JM
als Antwort auf: Anonymous
… hi @Anonymous
… to get to a nice and good render you have to be patient
… you need to tweak your environment lights, artificial and sun and a lot of detail
… take a look into these links, they will explain how to do it
…. https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Revit-DocumentPresent/files/GUID-15DFD1DB-0D3D-48B1-B7C7-6E0B82880F16-htm.html
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/Revit-DocumentPresent/files/GUID-AC50D6C6-56E2-40BF-96BF-EC1E31E0020B-htm.html
… do you mind uploading the .rvt file to take a look?
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Nachricht 3 von 6
aRcHiTeCt.JM
@Anonymous
… take a look at his exterior render filled with entourage, lights, all kinds of elements
... with a couple of more elements you will get a better more real result
aRcHiTeCt.JM
REVIT EXPERT ELITE
Nachricht 4 von 6
als Antwort auf: aRcHiTeCt.JM
thanks, but why they show as a solid elements?
Nachricht 5 von 6
aRcHiTeCt.JM
... can you please upload your .rvt file?
.... it looks like those are showing some kind of reflection
... do you have an image from that rendered at BEST ?
aRcHiTeCt.JM
REVIT EXPERT ELITE
Nachricht 6 von 6
thanks. I will try to render it in best quality.
No, I can't upload the project file
