Im having the same problem. Do you remember which file you deleted to solve it?
Gelöst! Gehe zur Lösung
Gelöst von mcernello. Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
Hi @mcernello
Please delete the log files in your temp folder and see if that help resolves the issue.
The daily collected data is stored locally in vray-telemetrics (V-Ray for Revit 20xx).log files viewable with a text editor. The files can be found in the Windows temp folder C:\Users\<username>\AppData\Local.
Please select the Accept as Solution button if my post solves your issue or answers your question. Kudos welcome!
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
@mcernello Did that resolve the issue?
Viveka CD
Thank you Viveka. It did help to narrow the problem. The file that must be deleted is "VRay4Revit.ini" in location %APPDATA%\Chaos Group\V-Ray for Revit 20XX
Solution came from chaos group support.
