When rendering in the cloud in Revit LT, is there a way to select Indoor Artificial lights only, Indoor Sun ONLY, etc settings like in full version of Revit? Or is that not an option in the cloud?
I know you can still set the exposure and White points, etc. just want to see about focusing on the lights.
you can refer to this LINK and see if helps. thanks
I appreciate the link the only issue with that is there is NO rendering ahead of time in RevitLT, you have to do it in the cloud versus having the option with the render dialog box, as shown in your link.
That was the box or information I am trying to find in the cloud settings.
See my attachment
Thanks Brian
i don't think it is possible at the moment. you need to set your settings within your file and render in the cloud. you may try to refer to this LINK. thanks
I can confirm the problem. Even when I set Artificial lights only and it shows properly in Revit LT with realistic visual style, the rendering output in the cloud is Sun only.
Tom
