Rendering families in projects material issue
1 ANTWORT 1
Nachricht 1 von 2
139 Aufrufe, 1 Antwort
Hello Everyone,
    After creating a new family with SketchUp imported file ( layers with no material) for my Revit project,  I added the material from the Revit and load it into the project, the materials are not shown after rendering.
Please if anyone had the same issue and solved it.
best regards,
hsn.shekh
1 ANTWORT 1
Nachricht 2 von 2
dzanta
als Antwort auf: Anonymous
depends on how you applied the material.
I downloaded a sample sketchup file and applied the material to the model by doing the following:
1. start new generic family in revit
2. imported sketchup model
3. full explode sketchup model
4. select each entity and applied material via properties palette (not material parameter creation)
5. started new project (architecture template)
6. load family into project
7. went to 3d view, set view as realistic
8. rendered as high
see attachment
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
