Rendering Advise
3 ANTWORTEN 3
Nachricht 1 von 4
432 Aufrufe, 3 Antworten
Rendering Advise
Hello
I struggle to get a nice look in renderings with large curtain walls.  The interiors are very dark.  I have tripled the interior light compared to what will be there in reality.  But the interior still is very dark.  I rendered the same view as a dusk/night view and the lighting it so intense that the image is not useful.
I have adjusted the glass tint and it seems to jump from Dark to Clear.
I'd rather not have to keep using Photoshop to correct this.
The render cloud seems to disregard my lighting settings.  The Sun setting seems to be the only thing that it picks up.  Where can we control what the render cloud does?
I would love to get some useful suggestions.
Nardo
3 ANTWORTEN 3
Nachricht 2 von 4
s.borello
als Antwort auf: Anonymous
Check out the rendering forum... you will get more hits over there.
https://forums.autodesk.com/t5/rendering-forum/bd-p/2060
Nachricht 3 von 4
https://www.youtube.com/watch?v=RvB2fph5g3E
Try it! You'll like it!
Nachricht 4 von 4
An exterior rendering showing a bright Sunlight with a dark interior is more realistic. Try taking a photo capture both the building and the sky and see what you get.
If you want to fake it with interior lighting then you have to amplify the intensity to hundred even thousand times to compete with the Sun, or change the time of so the Sun is set, or overlaying two or more renderings in Photoshop.
From my point of view, renderings with a bright surrounding environment and a bright interior look fake and most likely are fake.
