Rendering, 2 walls on same plane, same material, different structure, different render output
grantkjones
grantkjones
Hi, I have a brick veneer wall and a 90mm timber frame wall, both with the same material finish, but they render differently, anyone know why and how to fix it?
ta
elzohry2007
whick render engine you use ?
grantkjones
@elzohry2007 I just used the built in revit.  Not the cloud one.
For a start, they don't look to be using the same material, judging by the different cut patterns shown in the plan.
grantkjones
@ToanDN This is what the walls are made of, whether this is the correct way or not I don't know.  I created a new material and just made it the colour I wanted, then adjusted the thickness to mimic the brick/cladding it represents.
