Render problems
Render problems
Render problems
i have worked with revit in 2 years now, but i have never been able to render i cloud, which is starting to be a big problem, because of my projeckt size's. I've tried altering names of views, file paths and so on, but none of it have worked.
diegoaev
If you have revit 2012 you need a plugin from autodesk website.
For other versions you should not be needing a file path since when you render in the cloud you havet have to signin to autodesk from revit itself (right top of revit window). Then you will go to view tab, in the graphics panel, render in Cloud.
Provide more info: revit version and screen shot of the top right corner of revit window for more help
