My render done in the cloud is blacking out the top half of my final image. This hasn't happened to any other view in my Revit file. I have duplicated the view, recreated the view, resorted back to an old save which previously rendered correctly. It is not a lighting issue, or sun settings, nor is there anything obstructing the viewport.
If I were standing in the space taking a photograph; its as if I am covering half of the lens with black paper. Any idea why this is happening and how to fix it?
THANK YOU!
Gelöst! Gehe zur Lösung
Gelöst von cbcarch. Gehe zur Lösung
Suggestions:
-If you have multiple Phases, set Phase Filter of View to Show Complete
-Use a Section Box to limit the area that the camera view contains--often called "culling" in the viz industry.
-Turn off or unload any unnecessary Linked Models and/or Cad. ( if any ).
-Turn off Raster Images ( if any).
- If any Design Options, make sure Main Model is current.
Try rendering natively in Revit to test, does the black area show in your render?
