Hi, is there a was to render in the cloud with a background image? When rendering in the cloud the background image disappears but if render inside Revit through the rendering dialog the background image is there.
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Thanks. That works when its not through a window. Do you know how I can fix that?
What works? Using a higher resolution image or adding the image folder to Additional appearance paths?
@sbspiegel wrote:Thanks. That works when its not through a window. Do you know how I can fix that?
Don't use a Background Image. Use a Decal instead.
https://www.youtube.com/watch?v=pKUgey3cpKg
Using a higher resolution image. I am still not seeing it when its through a window.
@sbspiegel wrote:
This doesnt work when its through a window
Maybe you can do something like this.
https://forums.autodesk.com/t5/revit-architecture-forum/reflection-of-mirror-incorrect/td-p/11171231
