Hi there,
I was trying to do some 3D still image renders and panoramas but I realised that my render in cloud settings do not match the final result.
For instance, my still image setting is final result with maximum quality but the result is medium quality. Similar to panoramas when 3000px render in cloud setting turned into 2000px as a result.
Does anyone know why the settings do not transfer over to Autodesk 360 rendering?
regards,
Ryan
Hi @Anonymous
Can you try rendering the images locally and verify if you get the same result?
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
