Render goes back before render starts and then cancels
3 ANTWORTEN 3
Nachricht 1 von 4
307 Aufrufe, 3 Antworten
Hi I'm trying to render a large image for a site board in a non camera 3D view. I've overridden the visibility of nearly everything in the model to just the main model (not links) and only walls, roofs, floors and windows etc.
The renders worked on smaller sizes/ dpi. Sometimes I get an unknown error message depending on my balance of image size and dpi. Below are the failed result and last week's smaller sized success.
Thank you in advance.
Thank you in advance.Screenshot_050817_054610_PM.jpgAERIAL - FOR SITE BOARD Draft 2.jpg
3 ANTWORTEN 3
Nachricht 2 von 4
Viveka_CD
als Antwort auf: Anonymous
Hi @Anonymous
I see that you are visiting as a new member! Welcome to the Autodesk community!
If reducing the DPI to 150 and using a Region to reduce the size of the rendering area works fine then it might be a memory issue for large resolution renders. If you are unable to render, empty or duplicate the temp folder. Revit uses the temp directory to store files when rendering.
The tmp and Temp directories are used to store temporary information. The locations of these directories are specified in the environment variables. All of the files in these directories can be deleted. However, if you try to do this while applications are running, you will not be able to delete some files because they are in use and locked.
You may be able to delete enough folders and files within the tmp directory to allow you to render. If you have emptied your tmp directory and you still cannot render, you can temporarily change the location of the tmp directory.
Follow these steps:
  1. In Windows Explorer, create a new directory and name it Temp2.
  2. Right-click the My Computer icon on your desktop. Click Properties.
  3. In the System Properties dialog box, click the Advanced tab.
  4. On the Advanced tab, click Environment Variables.
  5. In the Environment Variables dialog box, under User Variables, select the TMP variable. Click Edit.
  6. In the Edit User Variable dialog box, enter the path to your Temp2 folder in the Variable Value text box.
You should now be able to render.
Note: It is strongly recommended that you do not create a new tmp directory every time the old one becomes full.
Let me know if this works or we can check for other solutions. Provide/attach a screenshot of the error message and which version on Revit are you using? Is is recommended that you update service packs and install hotfixes.
Please mark this response as "Accept as Solution" if it answers your question to benefit other users seeking similar soltuions. Kudos gladly accepted.
Nachricht 3 von 4
als Antwort auf: Viveka_CD
Hi Viveka_CD,
I think it is a memory issue as I've started to work around by only rendering about a quarter of the image at a time. I've cleared the temp files and we do seem to be moving along in chunks now.
Is there any way to increase the amount of memory revit can access as I'm able to work on other programs while its rendering and this is an old but powerful machine? There are no error messages just the black image appearing very quickly, currently using Revit 2016.
Thanks for your help so far, I'd love if you had ideas about improving performance? Otherwise, very useful and much appreciated.
Regards
Eoin
Nachricht 4 von 4
Viveka_CD
Hi @Anonymous
Glad to hear that you've cleared up temp files and got the project rolling at a steady pace!Smiley (fröhlich)
HERE is an a link that discusses Revit and virtual memory
You also would want to take a look at how to Increase Capacity of System Memory
I recommend checking out the following forum post to improve performance of your Revit model
Please mark this response as "Accept as Solution" if it answers your question to benefit other users seeking similar solutions. Kudos gladly accepted.
