Render Glitch - Black Square - Revit 2018.1
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
jcortelyou
1774 Aufrufe, 4 Antworten
I'm not sure if this is unique to 2018.1 or not (since down saving is not allowed I can't test) but my rendering keeps getting to 100% looks great and then ends with a quarter of the final output image having a huge black square in the bottom left corner.  It does this with Exterior and Interior shots - Lights or no lights doesn't matter.  Anyone have any guesses or tips?
4 ANTWORTEN 4
Nachricht 2 von 5
jcortelyou
als Antwort auf: jcortelyou
It appears as though a Repair on Revit through Add Remove Programs has fixed the issue.
Nachricht 3 von 5
zamorama2
Can you elaborate more please? like which program did you remove or add?
Thank you!
Nachricht 4 von 5
als Antwort auf: zamorama2
I have noticed that over the past 3 versions i downloaded of revit ( 2019, 2020.1 , 2020.2) that i get this same problem although it is very sporadic and doesn't always happen..... Very odd.
stay zen ,
rcw
Tags (1)
Nachricht 5 von 5
diegus68
Same problem. I discovered that if the rendered image is lower resolution the black square disappears
mystery
I have the Revit 2020
20.0.0.377
