Im having an issue with Revit 2022 that when it is set to realistic the objects are flashing - they show up then dissapear
Gelöst! Gehe zur Lösung
Gelöst von cbcarch. Gehe zur Lösung
It is likely a GPU/Graphics Card problem with your PC.
Realistic View has been changed to use a "real-time" rendering system that uses the GPU, so an older graphics card and/or driver may not perform correctly. You might also try adjusting settings with Hardware Acceleration ON/OFF.
Is there any other way to solve this issue?
Ive turned my hardware acceleration off but the issue is happening again
