Hey. I have drawn a 6-story building. I would now like to copy the building. One copy with 3 levels. One copy with four levels. Any ideas on the simplest way to remove a level and bring the above floor down? I cannot remove the top level. Almost like Jenga.
Cheers.
A novice.
Welcome to the forum.
Use save as... to make the other buildings in their own file.
Each building should be in its own Revit file.
The site plan should be its own Revit file.
The three buildings should be linked into the site plan, moved into proper position, and have their new coordinates shared back to their individual files with unique coordinate names that reflect the situation. For example: "SiteName-Bldg01-Lot06" "SiteName-Bldg02-Lot06" and "SiteName-Bldg03-Lot06" or whatever makes sense for your situation.
