I am creating a Revit template and am trying to clean out the dimension styles. I copied a detail in from another project, changed all the dimensions to my new styles, but the old style still remain. Purge Unused doesn't identify them. I have selected all instances and it says there is only 1 instance. I have searched to make sure nothing is hidden and can't find anything. How do I remove these dimension styles (all styles labeled "NOPE")?
Gelöst! Gehe zur Lösung
Gelöst von cbcarch. Gehe zur Lösung
Are you sure there arent any dimensions hidden in any views? You can't purge something if its still in use.
Also, how have you got multiple styles with the same name? I didn't think that was possible. Have you tried renaming them to something different then purging?
Wow. This is like your car maker telling you that you need to take your car to some obscure gas station in order to do routine maintenance. When will Autodesk address their messy software?
Wow, that was helpful.
By the way, page with Dynamo graph "is not found". So there is no solution?
Your link no longer works. Don't bring a terrible attitude. Be helpful and not condescending.
