Remove Revit templates
brianwclayton1969
brianwclayton1969
Good afternoon, I have an issue with people and clients using or selecting the incorrect templates.
Where can I go to completely remove templates from the browse list. See attached pic.
Alfredo_Medina
File > Options > File locations > Project templates
The default path is in each user's computer such as: C:\ProgramData\Autodesk\RVT [version]\Templates\English-Imperial\...
Instead of erasing the default templates, using the dialog box mentioned above, you could configure each user's computer to find templates in a folder in the network where you have the official templates.
syman2000
You can also modify the Revit.ini to start the default template. Check this website for more info
https://help.autodesk.com/view/RVT/2022/ENU/?guid=GUID-D92C354F-D2A8-4F7B-A432-DF1EFAC80ACD
brianwclayton1969
Thanks to everyone for the ideas and direction I was over thinking and over complicating the process. I just needed the additional jump start.
Again I just over thought the process.
Have a good day!!!
