Remove Paint
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
2748 Aufrufe, 4 Antworten
Remove Paint
Hi everyone, there is any way to remove all paint used in a project with dynamo?
For example, i painted some walls with a material "Tijolinho", and now i want remove all paint used the material "Tijolinho", but if i do this manually it will take awhile
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
Have you looked or asked over at dynamobim.org?
Nachricht 3 von 5
L.Maas
als Antwort auf: ToanDN
Yes (s)he has.
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 4 von 5
If "Tijolinho" material is ONLY used for paint and nothing else, you actually don't need Dynamo for this.  Steps:
- Duplicate the "Tijolinho" material.  The copy will be named "Tijolinho (1)".
- Delete the orginal "Tijolinho" material.  All objects painted with "Tijolinho" will return to their original material.
- Rename the copy material to "Tijolinho" in case you need it again.
If "Tijolinho" material is used for paint AND other things, such as assigned to objects, then the method above with remove the material from those objects as well.  So, depends on how much you use the material, you may have to re-assign it to those objects, or not using the method at all.
Sorry, but my Dynamo knowledge is not up to par to create such script you are asking.
Nachricht 5 von 5
great, the solution is easier than I thought. Thanks for help
I'll duplicate the material and delete the original, and rename the copy.
