Remove 'negative symbol' in RELATIVE Spot Elevation
2 ANTWORTEN 2
Nachricht 1 von 3
1435 Aufrufe, 2 Antworten
Hi.
I've made a relative spot elevation symbol/marker to denote setdowns in our slabs.
It works perfectly fine apart from the fact that the value is shown as a negative. I would like to remove the '-' symbol prefix from the value.
Unit settings won't override this, and as it's not a parameter I don't believe I can make a formula to cancel it with a double negative.
Does anyone have any smart ideas?
2 ANTWORTEN 2
Nachricht 2 von 3
dferreira-blackwell
als Antwort auf: Anonymous
Just add Solid White region, If the family is editable or add solid white region in section or elevation to hide it.
Nachricht 3 von 3
kunalwadhera
Since it is by default there in System family, i don't think we can somehow change it.
But i do use Generic annotation in such cases.
I have attached a family in which you can write the value you want to display, and of course it will not have a '-' sign.
Cheers
