remove/hide all material and finishes parameters
joe.lohrePHSHK
joe.lohrePHSHK
I am looking for a way to get rid of all of my Parameters in Family types under Parameter in the Material and Finishes?  I know about the selecting on the single parameter and then hitting the remove button, is there a easer way to remove them all?
RDAOU
@joe.lohrePHSHK
In the subject you state Remove/Hide...then in the body of thepost you imply delete..You need to be more specific and elaborate on what you are trying to do.
  1. Are you trying to batch reset the Material parameter to by category?
  2. OR you want to Hide them so that used do not see them when loaded into the project?
  3. OR you want to delete them all and start over again?!
joe.lohrePHSHK
 want to delete all of the Material and Finishes parameters or any parameter that is under this area.
RDAOU
Option to delete all at once does not exist...you need to 7se dynamo...some python may be required.
A quick search... see this youtube https://m.youtube.com/watch?v=Bd_orGaeXUk
You should be able to find something similar on forum.dynamobim.org
joe.lohrePHSHK
Will check that out.
