Is there way a way to remove the glass from the glass filled panel railing? I can't seem to find anything in the balustrade settings that will let me do that
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
@emmanuelbeewrote:Is there way a way to remove the glass from the glass filled panel railing? I can't seem to find anything in the balustrade settings that will let me do that
Ha! I'm reading this totally different from @ToanDN. "Is there way a way to remove the glass from the glass filled panel railing"?. Sure. Change it from a glass filled panel. You don't just remove a portion of a family. You are either using it or you are not. Or am I reading you too literally. If so; sorry.
@emmanuelbee: SERIOUS? I must have completely misinterpreted you. What method did you use to "change the glass panel to none"?
