Aye,
How can I remove from Architectural "Floor Plan" structural beams?
When I'm configurations plan views they sometime appears.
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Set underlay to NONE
what do you mean overall?! In yours those halftones are underlay so you simply set the underlay to none
To switch off beams in general you can toggle the Structural Framing Category in Visibility graphics
No every thing is fine now, I was confused why structural elements showed up in floor plan.
I figured it out.
I figured it out.
You mean structural elements above showed in floor plan as per your screenshot? If so, then yes it's Underlay setting as suggested.
In general, I would not turn off major Structural categories (beams, columns) in Architectural views. If they are under a floor/slab then they will not show unless you set the view to wireframe or set the floor to transparent. If they are exposed then they should show or you drawing is misleading.
Yup, as RDAOU mentioned it, possibility to turn off
Sadly they are inside or below construction, and they started to showing out when i was configurating "Underlay" settings.
I inserted structural "beams" inside floors / walls.
