Does anyone know if it's possible to remove a Sheet from an Assembly (not delete it), so that it appears in the Project Browser under Sheets rather than being hidden away under Assemblies?
Gelöst! Gehe zur Lösung
Gelöst von L.Maas. Gehe zur Lösung
No, not possible. You can create a sheet under the Sheets tab or under the Assembly tab. But you can not move between them. So yo would have to recreate them.
Louis
Please mention Revit version, especially when uploading Revit files.
