Relocating Project moves the Internal Origin?
4 REPLIES 4
caraP2UMX
315 Views, 4 Replies
When I relocate a project I notice in elevation that the internal origin has been moved up as well, is this supposed to happen? Is there a way to relocate a project without moving the internal origin?
Labels (3)
4 REPLIES 4
in reply to: caraP2UMX
Relocate Project isn't moving the IO or PBP.  It's moving the Survey Point.
caraP2UMX
Hi @barthbradley, the Survey Point (SP) did not move, but the Internal Origin (IO) did and the Project Base Point (PBP) both did?
Just a note this is Revit LT 2023
It's just smoke and mirrors. The Survey Point moves - not the Internal Origin.
Internal Origin never moves. Ever.  You are just moving the survey point away from it and from the Project Base Point.
Forma Design Contest
