Relocating my DWG import
12 ANTWORTEN 12
Nachricht 1 von 13
575 Aufrufe, 12 Antworten
Hi All
I received a DWG from a client but i dont know how to clean it up i think it is all in one block. When i import the file into revit 2019 it says it is 33 miles away ?? Not sure what this means.
I need to get the model to be at 0,0,0 ?
I need to do the light design by placing the fixtures on the right place then render in 3d and i fdo have the textures as well
Please help.
I am very very new to this
Tags (1)
12 ANTWORTEN 12
Nachricht 2 von 13
rkmcswain
als Antwort auf: Anonymous
So here is the XYZ and NEZ from a random point in your model.
Does that look right to you? We don't know what your coordinates are, or are supposed to be.
The DWG is in WCS and the BASE is 0,0,0 - so that looks good.
R.K. McSwain     | CADpanacea | on twitter
Nachricht 3 von 13
als Antwort auf: rkmcswain
Hi there
Thank you for the reply however i am not sure what to tell you, i know that when i import the file into revit is says the file is 33 miles away from the point and i cannot find it on my screen. Is there a way to reset all to zero so when i import i can just place it on zero on the axis?
Should i send a screen shot of the error? Or how can i clean it up in and correct in cad.
Nachricht 4 von 13
Errors i receive in revit
Nachricht 5 von 13
rkmcswain
I know a Revit expert....... let ask ....... @kmfuhrman
Nachricht 6 von 13
You need to set up Shared Coordinates.
Link the DWG into Revit Center to Center. Move the DWG to the correct x,y, and z position REALTIVE to the Revit Model. Go to Manage Tab=>Coordinates and press Acquire Coordinate and select the Linked DWG.  Save the Revit Project/Shared Site Position.
Nachricht 7 von 13
kmfuhrman
als Antwort auf: barthbradley
Check out this forum post...
https://forums.autodesk.com/t5/revit-architecture-forum/geometry-in-the-file-has-extents-greater-tha...
Kimberly Fuhrman, LEED AP BD+C
Freelance Architectural Technologist
Nachricht 8 von 13
This is an extraordinarily amount of data and extents.   How much of it do you use in your Revit Project?  What of the dozens of layers of information here are relevant to you for your purposes?
Revit Site Plan View...
Bottom line: it's unmanageable as a whole.
Nachricht 9 von 13
hi there
I basically need the building, parking area , basement and the signage etc.
I only need to do the lighting outside and inside. I dont need the
electrical layout for instance
Nachricht 10 von 13
als Antwort auf: kmfuhrman
Hi there
I am sorry but i have no idea how to do what was said in the post.
- turn on and unfreeze all layers
- bind/insert/remove all xrefs
- changed the origin of the dwg to 0,0,0
- Zoom extents and removed extra geometry
- explode all
- create a new block and create new dwg
- cut and paste into new dwg
- purge and audit
- removed geolocation from the CAD file
Nachricht 11 von 13
Freeze and turn off every layer you don't need and repost your DWG.
Nachricht 12 von 13
Hi there
I did as you requested as far as i can. I dont know if it is ok. I also
have all the textures etc if needed.
I am not sure how to repost to you on the site? Is there an email address i
can send the file via we transfer?
Nachricht 13 von 13
pendean
Ask the DWG file creator to send you only what you need: the file you posted is overly cluttered and all XREFs were bound which makes it a challenge for you to do what you want. It's basically garbage for your use in REVIT.
The content is also very far away from the AutoCAD "start" of 0,0,0, about 30-ish miles away.
This DWG file needs work on its own before you can use it IMHO.
