reinitiate revit properties palette disappeared
5 ANTWORTEN 5
Nachricht 1 von 6
phyrrus
839 Aufrufe, 5 Antworten
5 ANTWORTEN 5
Nachricht 2 von 6
martijn_pater
als Antwort auf: phyrrus
Go to view, dropdown on the right tick properties for User Interface setting.
Nachricht 3 von 6
PavelAnd
Hi, @phyrrus . You can use keyboard shortcuts for showing this menu: PP, or CTRL-1, or VP.
Best regards, Pavel Plotitsyn.
Nachricht 4 von 6
phyrrus
als Antwort auf: PavelAnd
more complicated than that tried view panel pp etc still nowhere
Nachricht 5 von 6
martijn_pater
That doesn't do it? (or shortcut PP, rightly pointed out above...) Try unticking/ticking the box and see what happens. If nothing, then I think you might have to consider a reinstall...
Nachricht 6 von 6
RDAOU
@phyrrus
If none of the above works, try the solution given on the following link
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
