Regex In Filters
5 ANTWORTEN 5
Nachricht 1 von 6
SometimesInventorMakesMeAngry
314 Aufrufe, 5 Antworten
Regex In Filters
I'd like to select any items whose property is KA-01-A, KA-01-B, KA-01-C, ..., KA-01-H (between A and H at the end). I could easily match this with regex /^KA-01-[A-H]$/, but I don't see an obvious way to do this in Revit. I can't do it one by one because I can't fit that many filter rules to do it with a bunch of ORs. Is there a way to do this?
5 ANTWORTEN 5
Nachricht 2 von 6
Hi @SometimesInventorMakesMeAngry,
You mean ViewFilter Rules?
Why would OR operaters not work in them, 8 rules (to H) are possible. (What Revit version btw?)
Or depending on the parameter intended use, use a secundary field as a integer/or number.
And use A=1, B=2 etc, now the filters can be reduced and easier set.
First Rule would be:  Starts With "KA-01-"
Second Rule wound be: Less than 9
Filling in the 1, 2, 3 etc efford would depend on the elements/parameter, does a single element have "KA-01-A" or many, in the last case a schedule grouped by that parameter would easy to fill in the integers/numbers.
Nachricht 3 von 6
You can create a schedule, add 2 filters to the schedule:
- include KA-01-
- less or equal to KA-01-H
Then your schedule will only show element from KA-01-A to KA-01-H and you can highlight rows in the schedule to select the elements in the model.
Nachricht 4 von 6
@ToanDN :
- include KA-01-
- less or equal to K-01-H
do you mean "KA-01-H"
Nachricht 5 von 6
Thank you! This works! However, I also have KA-01-AA, KA-01-AB, ..., etc in the list. Those are still present.
Nachricht 6 von 6
Can you please elaborate on this part?
"use a secundary field as a integer/or number.
And use A=1, B=2 etc"
