I am facing a problem in Revit about reflecteted beam
Example: I have 2 floor plan with beam
I want to see beam of 2nd floor plan on my 1 St floor plan with using of range base level
Bt it shows everything whatever on 2nd floor plan. And its very difficult to read structural beam.
if Autodesk add a new reflected model categories in visibility graphics. in later version.
It helps to work for better drawing quality and good co ordination with structural model.
Underlay....show next level looking up....use the Linework tool on anything you want to show on the floor plan, like the <overhead> line type. Turn off the underlay and you still show the lines. If a beam moves so does the lines.
thanks for the suggestion, but i find out the new solution for reflected beam, which is easy and useful method for every revit user, it helps to cordinate with structure model or element, ill send the video clip soon,
