Hi everyone,
I’m looking for guidance on how to display the tread lines of stairs in a ceiling plan. I’ve attached the default view of the stairs, but I’d like to enhance it to make the tread lines look more realistic. Any help would be greatly appreciated!
Thank You!
Gelöst! Gehe zur Lösung
Gelöst von jay_colcombe. Gehe zur Lösung
Unfortunately this is a limitation in Revit at present You would need to create a Plan Region for this and set the following;
View Tab > Create > Plan Views > Drop Down Arrow > Plan Region
Draw the Plan Region around the Stair > Select the Plan Region Plan > Properties Palette
Primary range:
- Top: at bottom of stairs
- Cut plane: below stairs
- Bottom: same as Cut plane
View Depth: above top of stair
