Reflected Ceiling Plan sprinkler heads
2 ANTWORTEN 2
Nachricht 1 von 3
2056 Aufrufe, 2 Antworten
In my model, I have two different ceiling heights. 9'-0" and 10'-0. I am trying to create a demolition RCP. I am using the same sprinkler head family in both ceilings and they are showing up as different sizes and different poche colors. They are all on Phase Created existing and Phase Demoiliton: New construction.
Its the same sprinkler family inserted into both cieilings. Why are these not showing the same?
Thank you,
Cam
2 ANTWORTEN 2
Nachricht 2 von 3
L.Maas
als Antwort auf: Anonymous
Can you upload part of your project with the issues (the two ceilings and different sprinklers)?
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 3
I know this is very late, but since nobody seems to have answered it I'll have a go.
I experienced the same thing and I found that the View Range of the plan is the one that's causing the size issue. If you make sure that all sprinklers are withing the Primary Range of your View Range, it should appear with the same size.
As for the color, I found that the cause could be that graphic overrides of the system they belong to. In my case, some of the sprinklers didn't belong to a system, causing them to show their default black color, whereas the others are shown in red according to the graphic overrides of the System they belong to.
Hope this helps anyone who comes across this problem.
