I want to be able to create a ceiling plan callout on a ceiling plan view that is placed on a sheet. Then place the callout on a sheet with a view title that displays the referencing sheet (the one the ceiling plan is placed on).
I have a view title family with a label to display referencing sheet. It works fine most of the time however it often references the wrong sheet. In the case of my ceiling detail it references the sheet the floor plan is placed on not the sheet the ceiling plan is placed on. Again the ceiling callout was created on the ceiling plan view.
Any thoughts? I did check that the view range of the ceiling plan and the ceiling plan callout are both tight against the ceiling well above the floor plan cut plain.
I'd appreciate any assistance as I have not found an explanation in Revit documentation.
