I have got two separate (but related - they are parts of the same building) projects that employ a lot of common details. Currently, they have set up a blank detail sheet that tells the contractor to look at Detail X on Sheet Y. Not a very elegant or efficient solution, to my mind. Is there any way to reference the common details from the related project? Are there any workarounds that can be used?
Gelöst! Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
Hi @Sahay_R
One option would be to set up a separate project with these common details and link it to your main Project.
Or you could create reference callouts and set those views to By Linked View
Please select the Accept as Solution button if my post solves your issue or answers your question. Kudos welcome!
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Hi @Sahay_R
Also, check out this AU class on How to link details to multiple projects in Autodesk Revit and see attached document.
Viveka CD
Thank you, @Viveka_CD! I think that the By Linked View option will serve us best. The AU handout that you mentioned will come in handy for a fortcoming project, where we see something like this happening.
You are very welcome @Sahay_R
Glad to note that you found this helpful!![]()
Looking forward to hearing about your forthcoming project and which of these tips best served your purpose.
Viveka CD
@Viveka_CD - Actually, I did attend this session at AU2017. I don't think that this approach will be very successful with the way that we work.
So back to the drawing board, now.....
Hi @Sahay_R
I'm wondering if we have information in this regard, let me scan through and get back to you.
Thanks for pointing that out - can you post the link to that course when you have a chance?
Viveka CD
@Viveka_CD - it's exactly the same as the material in the link that you'd sent me.
Very true. But doesn't work with the way we work.
@Sahay_R Hmm, I see what you are saying.
Is there anything you can suggest - maybe a workflow, let it be in theory for now and we can work on it together.
Viveka CD
A couple of things about the project - they are similar / identical buildings, which means that in addition to details we are talking about things like wall sections. Building #1 documents are under way. Getting prepped for common details to be added to the remaining buildings would be a part of what we would need to think of.
