I'm currently trying to add a view reference to a detail view that I have in my project, however, it's not letting me draw the reference horizontally: the detail view I'm referencing is in plan, but when i go to draw the section (with the detail already specified as the referenced view), it only lets me draw them vertically. basically, this is what i want, but it's not letting me do anything other than vertical section references
Gelöst! Gehe zur Lösung
Gelöst von jay_colcombe. Gehe zur Lösung
Gelöst von Alfredo_Medina. Gehe zur Lösung
You need to draw the section vertically, and then rotate it. I don´t know why it happens, but it has always been that way.
You have to use view reference object for this
Just to clarify, when you click the Section Tool before you draw the section line are you changing in the Properties Palette the View Type to “Detail View" from the Type Selector. This allows you to draw horizontal sections with the view/sheet reference head
