Reference lines in adaptive family
4 REPLIES 4
zhelun.zhu
416 Views, 4 Replies
Hello everyone,
 I noticed this issue during the form creation with reference lines in an adaptive family.
In particular, I have used a parameter to control the dimension of the profile along the reference lines and as you can see, there are two different behaviour for the resulting geometry (opened or closed path). I didn't expect this kind of problem since no model lines has been used.
Has anybody else met this proble before? Did I do anything wrong?
4 REPLIES 4
in reply to: zhelun.zhu
@zhelun.zhu wrote:
Hello everyone,
Open or closed path is not the issue. The issue only pertains to path with 2 points.  To fix it, place a profile at each end of the ref line instead of a single profile in the middle, then select the two profiles, NOT the path, to create form.
RDAOU
@zhelun.zhu
Depends on what is being modeled and how is it expected to behave or be used. Solutions vary, Using Nested Profiles, using repeaters on a divided path to make the loft more sturdy...etc
But also in a case similar to what you demonstrated simply Locking the profile might suffice
zhelun.zhu
in reply to: RDAOU
Thank you ! that's what i was looking for !
Forma Design Contest
