I've run into a unique issue where whenever I create length based instanced parameters between two reference lines, the instance shape handles show up as expected in plan, section, and 3D, but are not visible in elevation. Anyone know if there's an additional setting to apply, or is this a bug that will hopefully be resolved? See attached screenshots. (Elevation cut line is at the midpoint of the elevation circle and the far clip offset is beyond the component in question)
Thanks!
3D with grips:
Plan with grips:
Elevation without grips?!?!?!
Can you share your example? It ought to work in elevation too.
Steve Stafford
@SteveKStafford see attached component, check it out to see if you can replicate.
It worked fine when I loaded it into a project. The elevation (or section) must be parallel to the family. If yours (elevation view) isn't then that would explain it.
Steve Stafford
Looks like the reference pline is a bit behind the box, maybe increase the Far Clip Offset a bit so you can "see" the reference lines in your elevation.
In the Elevation view you've unchecked the Visiblity of the Reference Lines Category ???
