Reference Line Grip for Rotating Element
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
crapai
909 Aufrufe, 5 Antworten
I'm tring to get a grip to control the length of a model line that rotates. I am able to get the grip to appear and control the line but only if I have it measure from another referene line that is set to weak reference atleast. This causes another grip to appear that I do not want. Is there a way to do this without getting the extra grip?
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: crapai
Like this?
Host elements to Ref. Line Work Plane.
Nachricht 3 von 6
crapai
als Antwort auf: barthbradley
It looks like the family you posted still has the same issue. The reference line at the insertion point still have grips.
Nachricht 4 von 6
RDAOU
@crapai
If you want a single grip, you will need to dimension to reference planes ... dimensioning to Reference lines will give you either 2 grips or NONE.
See gif below...generating a single grip by dimensioning to a reference plane. Grip will not be at the end of the model line but will function like a slider
Nachricht 5 von 6
crapai
I figured that this would be the only option. Thank you.
I marked as solved, but for the record the answer is, you can not.
Nachricht 6 von 6
FAIR59
a labeled dmension between a model-line and a reference-line will also give you 2 grips. If the visibility of the modelline is unchecked, you end up with just 1 grip. The modelline is too weak to act as an anker to move the reference-line, so this is for "cosmetic"purposes only.
Starting with the family you posted:
  • make the reference-line at the pivot point [ Not a Reference ]
  • set workplane to the rotating reference-line
  • draw modelline perpendicular to the rotating reference-line, near the pivot point
  • uncheck the [ Visibility ] parameter of the modelline
  • add a dimension between the modelline and the reference-line at the end of the rotating reference-line.
  • label the dimension with the [ Length ] parameter.
