Reference a value from a schedule to a parameter
In Revit schedules you can do calculations such as total area.
Is there way to have a column be a parameter that references that total?
Or is there a way (like in excel) you can have a parameter equal to the sum of another column?
The parameter is supposed to show in 'project information' for exporting purposes.
L.Maas
No this is not possible woth OOTB Revit. The only possible solution would be to do this programmatically (e.g. with dynamo).
Louis
Please mention Revit version, especially when uploading Revit files.
