Redundant Room Warning
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
vitorbortoncello
209 Aufrufe, 2 Antworten
Is there a rule or priority in Revit for excluding redundant rooms without selecting it through the warning dialog?
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
2 ANTWORTEN 2
Nachricht 2 von 3
Hi @vitorbortoncello,
Not exacly sure what you mean, a "another" way of selecting / finding the redundant etc rooms?
Then create a RoomSchedule, add Name and Area (minimal) and check the option "Isolate" in the "Not place/...." panel. I use these kind of schedules as checking tools and are setup in the Template.
Now the schedule will only show the Redundant, Not Enclosed and Not Placed rooms.
Select and highlight in model and edit as needed, also add as many Fields to id the rooms/locations, like level...
- Michel
Nachricht 3 von 3
yes, that works!
