Red Lines around windows
info
info
Windows seem to have thin Red Lines around the window sashes & frames. It appears to be a default setting all the windows I create in Revit seem to have them.
I've got a fixed window with blue lines. How can we switch them off?
I'm using AUS windows families, I don't know if that makes a difference.
Please see attached.
Does it go away with different View Detail Level (Coarse, Medium, Fine)?  Is the linework on it's on Subcategory or associated to a Visibility Parameter in the Family Properties?
You can always post the Family here.
info
It does not make a difference with the detailed level.
I've attached 2x window families, I've modified them both. But the red was present before hand.
Change these subcategories color in the project's objects styles to black if you don't want to see the colors.
