Guys, we VG and set revision cloud to red color. Some projects will automatically make the clouds in red. Some projects the cloud still come out in black, and we still have to do VG again for each sheet. Our projects set to revision per sheet by default. We have no idea why.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
it could be there is assigned view template in the view?
If you want to change all of the revision clouds to red, I think the easiest way is to change the setting in Object Styles(as @ToanDN said).
Manage-->Object Styles-->Annotation Objects-->Revision Clouds--Line Color
Additionally, I guess the issue you come across maybe because that some of the revision clouds were in "views" while others in "Sheets" which are controlled by different VG settings.
CONG XU
您认为此帖子是否有用?欢迎为此帖点赞。
您的问题是否已得到解答?请点击“接受解答”按钮。
@yes_and_no wrote:Guys, we VG and set revision cloud to red color.
How? There are many ways to change the VG of elements. By Filter, By Element, By Category to name three. There are also hierarchies of overrides that could affect.
