I don't know what this symbol is called that has these arrows and other elements connected. Until this week, I have been able to hide them through 'temporary hide' option. This week, everything hides except these arrows. I'm not sure why this has occurred. The vertical & horizonal arrows remain the same size when the drawing is zoomed in or out...meaning the arrows' size seems to be larger when zoomed out and smaller when zoomed in. I looked in Visual/Graphic overrides but didn't find anything. Any suggestions?
Are you talking about MEP conectors?
No, architecture. I believe they are directional arrows.
I tried to down a PDF but it showed error code
The arrows are a part of the "site: project base point" I've hidden, in the past, by the "temporary hide" feature, but now the arrows remain. Thoughts?
How does one do that?
How does one turn off something in Revit? Via Visibility Graphic Overrides.
VG > expand Site category to reveal subcategories > uncheck Internal Origin box.
You need to be more specific in order to be helped. Can you share a screen capture? Are the arrows attached to any given element? It happens everywhere in the model or in a given floor plan, section, 3D? Wich 2020 version release?
