Rectangular shape rotation in Generic family with center as basepoint
4 ANTWORTEN 4
Nachricht 1 von 5
659 Aufrufe, 4 Antworten
Hi All,
I have a simple generic model rectangular family. I need one parameter for rotating the same with center as base point. Please advise.
Thanks & Regards,
Bujair
4 ANTWORTEN 4
Nachricht 2 von 5
Alfredo_Medina
als Antwort auf: Anonymous
Welcome to the forum.
  • In the plan view, create a reference line starting at the origin, to the upper right quadrant, to any length, any angle.
  • Align and lock the start point of the reference line to both reference planes, one at a time.
  • Create an angular dimension to control the rotation of the reference line, and convert the dimension into a parameter.
  • Set the parameter for rotation to zero.
  • Select the extrusion (or the sketch) and select "Edit work plane", then select the reference line.
  • Now you have control over the rotation of the element, with the parameter.
Nachricht 3 von 5
als Antwort auf: Alfredo_Medina
Thank you for the quick replay.
I tried, but it freely rotating. I need rectangular center as base point.
bujair
Nachricht 4 von 5
Use a nested family to simplify the constraint.
Nachricht 5 von 5
Alfredo_Medina
You missed one step. Set the rotation to zero before using Edit Workplace.
