Rectangular Corner Mullion
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
jagostinho74
1078 Aufrufe, 3 Antworten
Is it possible to create a rectangular corner mullion to achieve a similar effect as the image below?
The one being used below is a regular border mullion with a rotation applied. But I have multiple contexts and would not want to have multiple types for each rotation.
Many thanks
J
Assistant BIM/CAD Manager
Manchester, UK
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: jagostinho74
This is a tricky request. I would remove the system mullions and add a model in-place mullion.
Design wise, if it a curtain wall system, I wouldn't put a mullion there like you show it. Depends on the angle, you may end up with an expensive custom detail. Think about about how the glass interfaces with the mullion. Look at the some curtain wall manufacturers' details see what are available. I would either have a butt joint if possible.
Nachricht 3 von 4
jagostinho74
als Antwort auf: ToanDN
@ToanDN
We try not to use In-Place elements as much as we can when we model but I guess that for this case is the best option available.
Quite right on the point you make on the constructability of the CW.
Many thanks for your reply.
Kind regards,
J
Manchester, UK
Nachricht 4 von 4
You can create corner mullion by choosing one of availble in Revit. In Revit are 4 type availble corners mullion. Before adding you have to remove the existing one, then choose new one (one of corners type) and add it.
It can look f.e. like in the attechment, but of course, you can edit mullion to achieve yours expectations.
