Recessed can lights - edit family in section
2 REPLIES 2
ukicenic
304 Views, 2 Replies
Both these photos are in elevation. One is inside the actual light (in section). How do you do that?
2 REPLIES 2
in reply to: ukicenic
Move the light source.
Open an OOTB Recessed Can Light and see how it is controlled through the use of a parameters. Light Source Symbol is locked to a Ref. Line. You could also control the location of this Ref. Plane relative to the floor, or bottom of can, or whatever - effectively moving the Light Source Symbol with it because it's locked the Ref. Plane. Additionally, note that Light Source Symbol has a "Distance" property (e.g. the length of the beam cast).
NeginGHShir
If you want to see the light in its family like picture 2, then try to change your visual style from Hidden line (Picture 1) to Wire-frame (Picture 2).
If you want to see the light source (Yellow Lines) In your views like section in the project, then mark the Light source icon in your visibility & graphic window.
If you find my post is interesting, I will Appreciate it if you give a Kudo.
If it solves your problem, please click Accept Solution.
Rail Community
