The OTB receptacle automatically reporting the room name (where it located) in the panel schedule. My guess it has something to do with room bounding (can be wrong, obviously).
The OTB electrical panel indeed has no such luxury.
Q: how can I make such subpanel to report the room location to main panel schedule. It would be nice for it also to report such location in its own schedule panel, automatically.
Any one ?
What version of Revit are you using? The panels in the stock template in Revit 2024 do report Location automatically.
Steve Stafford
I m a bit confused why reporting in plan view the room location, which is obviously there already.
I modified the tag in my image to show the Location parameter, to demonstrate that it is reporting the same information as the room name. The stock panel tag does not have location, just panel name. Location used to only work with Spaces but I don't recall which version that changed in.
Edit: sorry I had that backwards in my memory...location used to only work with Rooms but we don't usually add rooms to MEP models, we use Spaces.
Steve Stafford
