Hi Revit team,
It look like Revit 2017 do not support the constrain dialog to take the constrain target for rebar like Revit 2016 ?.
Hello
Autodesk have made some improvements in 2017 (in my view very nice improvements). Rebar constrain function is there. It just have been modified. You can choose between few surfaces in order constrain a rebar to, it was something that I missed in 2016.
Thanks. But I like to make a rule to assign for all rebar. In the case i create the rebar for cantilever beam support balcony, the actual length of beam is 900mm but in the reinforcement dialog is 400mm. What wrong with it ?.
