Here is what I am talking about -
The red tag is the original tag. Three generic notation tags were nested into one, with text parameter labels set to be 3/32" tall with 1/2" tabs.
The blue tag is a copy of the red tag. When the value of one is changed to MULTI, all the text changes to be a little larger. This difference in size is obvious enough to be redmarked during QC, hence the concern.
When I take the same tag and drop it into a virgin project, this behavior does not occur. It stands to reason that there is something going on with the project file. The question is - what?
Gelöst! Gehe zur Lösung
Gelöst von Sahay_R. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
idk...what if before you drop it preparate the virgin file. Delete all Annotation symbols and then transfer project parametrs from first project. then try to drop it.
@Stanis-74 - thank you!
Did a Transfer Project Standards from a clean project - did not change anything.
Sorry! It sounded like a great idea!
This should be explanatory - where I demonstrate the behavior in the project, and then in a clean project.
Is the Project File originated from a pre-2017 version, then upgraded to 2017/2018?
Yup. 2015, possibly 2014.
So this is the dreaded 2017 Text Bug? Good catch, @ToanDN! Any way out? Would replacing the font in the tag work?
Ok - here it is - some geometry from the old project was copied into a new file. Possibly this could have activated the dreaded Bug.
What I did was edit the tag family and switch to an older, but similar font that we used. Voila! Problem solved!
Thank you, @ToanDN, for Showing Me The Right Path!
