created a sloped building with curtain wall front. Can not get the 3d to show up realistic / fine
ie when I made the outer walls brick, etc, it does not display this way
Have you assigned the correct materials to the brick? In the Materials Editor, have you checked the Use Render Appearance checkbox for the Brick material that you have applied?
Can you share the file?
