Realistic View???
Realistic View???
LisaDrago
Advisor Advisor
Realistic View???
LisaDrago
I have been having an issue with using the Realistic View... it used to work... now it doesn't.
What setting got messed up? I can't figure it out. Can anyone help me?
Image attached.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: [email protected]
ryan.duell
From the screen capture, it appears that Hardware Acceleration is disabled [which is necessary in order for the material texture maps to display].  I would check under R > Options > Graphics > Graphics Mode, and check Use Hardware Acceleration.
Ryan Duell
LisaDrago
Thank you!
It is the little things that trip me up...
LD
